1 - 20 of 356 Posts
ok guys im planning on going for the elusive stock motored 12 second timeslip in my newly acquired 89 coupe. im going to try to do it using as few parts as necessary. im just curious what all you other guys are using that have run 12s (and very low 13s) with stock heads, intake, and cam
now i know theres several of you out there with these sort of cars and doing a search brings up a lot of good info, id just like to see it all in one thread so im hoping this catches on
so far my short list of what im doing to the car is as follows
4.10 gears
dynomax race magnums
off roah h pipe
bbk shorties
short belt
race crank pulley
all the free mods i can think of (bumped timing, removed fan, iced intake, etc)
either slicks or bfg drag radials havent decided
i plan on starting of with stock suspension parts and see how well it hooks before adding any parts. the car seems to have pretty decent weight transfer stock so im hoping i wont have to buy anything right away. probably will just end up going 4 cylinder springs and boxed control arms
I'm assuming you are keeping it full weight?
You're list 'o' stuff looks good. I wish I'd have done 4.10's the first time. I'm swapping 3.73's to 4.10's at the end of the month... grumble grumble...
unless you are going to run in class events like trophy stock, and such, I'd go with long tubes.
drag radials will get you there on a perfect track and with suspension work, but, you'd be better off with a real slick if you are keeping the stock suspension, well, at least that's my experience. As a matter of fact, you may want to consider a 28" slick and 4.30's...
stock fuel pump is gonna need a look at.
You'll likely need a MAM, or at least bore the stocker to 60mm's.
Skinnies will likely be required as well.
I'm gonna enjoy watching you. Have you baselined the car yet?
Mike H.
You're on the right track man. Technically I didn't do it, though my times would have elevation-corrected to a 12.76. Ah well.
Forget drag radials, they're a waste of time. Go with full slicks or nothing at all.
id like to keep it close to NMRA Factory Stock legal, thats the main reason for the shorties, plus i already had some laying around. i doubt ill ever make it to any races but just in case it would be nice to be able to run, ill probably switch to gt40 parts next summer but want to try the stock 12s thing first.
not sure on weight of the car yet, my last coupe weighed 3480 with me in it stock, im hoping this ones lighter :eek: id like to get it down to under 3200 so the AC is going along with the smog crap and any other non essential stuff. the PS has to stay (though ill probably bypass it for awhile)
im hoping to begin swapping in the T5 this weekend (currently has a blown up AOD in it, last chance for track times will be the 1st of nov so im hoping i can make it
Go with an X pipe, 4.30s and a taller tire IMHO.
Might want to consider an airbag in the right rear as well. You're not a small guy, so any weight transfer you can get, the better.
Maybe consider some 70/30s and a tubular front end. Battery relocation would certainly help you out.
MIKE! Hey don't do anything yet! Baseline the car and see what it will run now before you go addin stuff. Your list looks good. I wouldn't worry about doing headers and mufflers yet. You'll see much bigger gains out of just replacing the h-pipe. Also I didn't see it added but I'd get a new motorsport timing chain and retard the timing 4 degrees. Also call Downs Ford in Toms River, NJ and get a bored stock MAF. Those are about $30 and worth a solid tenth. Go slicks and stock suspension. Remember to remove the front sway bar. On the gear selection, I'd always prefered 3.73's over 4.10's. The only advantage that I saw with 4.10's would be if you plan on running a 27" or 28" tire.
I can't wait to see how ya do!
Take care
Al Renkel
3.73s aren't enough gear....well, they may work, but it'd be easier with 4.10s. The car will trap ~105 with a stock motor and you'll still have plenty of powerband left with the 3.73s. Use all of it that you can. If it were me doing it again I'd put 4.30s and 27" beef on it.
Get the headers and catback, it's just that much more power you're gonna add. The C&L 76mm MAF was worth a solid 3 tenths in back to back testing against the stocker at the track.
Hmmm plenty of powerband. Well my car made power right to 5200 in 4th gear and I went thru the traps right at 5300 on a M/T 26x8.5. 4.10 would have put alittle too far above my cars powerband in my opinion. Every car is different
One of the originals Stockers
Al Renkel
hiya al
im thinking about running it with the stock headers first and then swapping to see if it makes an actual difference. im gonna try my best to do one part at a time to see what really works, ya know. sucks winter is here so i gotta wait til next year to really do anything. the car has 2.73s currently so if i can make it to the track on the 1st that should be interesting
was planning the timing chain, 4° retard and some fresh valve springs (and possibly a fresh valve job)
FWIW my old coupe went 99.7 mph when it was stock with only 3.73 gears and full exhaust, it weighed in at 3480lbs. figure if it had weighed 3100-3200 that would have been an easy 102-103 mph and on slicks should have been good for low 13s with hook
one thing on the gear is im running a T5Z with the 2.95 first gear (the 3.73s in my old car didnt seem like quite enough gear in 1st but i was using a 28" tire) im hoping the 4.10s would be a little better but still not TOO much. talked with a few factory stock racers and they are shifting at 6100 with stock retarded cams, not sure i want to go that high but if thats what it takes maybe 4.30s would be the way to go? i dont know. they are using 28" tires with 4.30 gears, i figure 4.10 with 26" tires would be about the same?
I think those stocker guys that are shifting at 6100 have those "stocker cams" The factory cam (unless they changed them) is not going to get close to making power till 6100. There is actually a big difference in the 4.30's and 28" tire vs. the 4.10 and 26" tire. The 28" and 4.30 give you a much bigger tire contact patch, plus the fact that the 28" tire sidewall is much taller allowing for the intial shock of the clutch hitting the tires to be reduced which helps to not blow the tires off. Mike I'm sure you will have no trouble with the 12sec barrier (remember the first time :D ) Anyway, start gutting that pig. Nov 1st gives you plenty of time so get hopin!...lol
Talk to ya later
Al
Wow.
Al Renkle... out from the depths... where have you been?
I cannot even find your web site anymore...
What was that Black coupe 60' when you did the "how to go 12's on a budget" article for MM&FF?
Factory Stock is about as factory stock as I am a movie star!
My factory original motor, with MAM and full exhaust makes peak power at 4900 rpm. With the stock hearers and tail pipes it made peak hp at 4800 rpm.
103mph with a 26.1" tall tire, and 3.73's puts me in the trap ast 4900 rpm... I need 4:10's to wind it out a bit more, and with original suspension, I need the help out of the hole as well.
4.30's would be more than I want on my street car (actually, I'm not sure the 4.10's are gonna ge all that great for street duty...), but as mention'd, would be great with a 28" tall slick for track duty.
I would recommend a 3.73 gear and a 26" tall tire. The shorter tire will provide less inertia to overcome than the taller one. Get a set of light weight wheels, Welds for instance. Anytime you can reduce rotating mass your car will accellerate faster. An aluminum driveshaft will help in this area too as will underdrive pullies.
Stiffen the chassis with SFC's and a good roll bar, I used a 6 point set up from Chassis Engineering. You will also want to use a sturdy set of LCA's and some adjustable UCA's if you can afford them. This will allow you to tune your pinion angle and make it launch better.
Get rid of all uneeded weight, weight is your enemy. The AC system and power steering is a lot of dead weight. Move your battery to the trunk. All this will help in weight transfer on launch.
Set timing to 14 BTDC, install an AFPR and find the best fuel pressure by track testing. My coupe liked 51 psi.
The only engine changes I made were to install a 65mm TB and a set of Cobra 1.7 rockers. The exhaust system was 1 5/8" MAC long tubes with a 2.5" off road H and Flowpath mufflers.
All these changes netted me a 12.76 ET at 106 MPH at a 3100# race weight. I think it would have gone quicker with more tweaking but I got greedy and swapped the heads, cam and intake after that. :)
My old 87 coupe went [email protected] with 3.73s,26x8.5 M/T slicks,all the free mods,U/Ds,Dynomax super turbos(mufflers only),and AFPR.Launched the car around 5500rpm,and shifted around 5200-5300.People at the track use to call me a liar,saying there was no way the car was that quick with so little mods.
Hi cleanLX,
I've been on hiatus.... :) The best 60' I ever had when the car was in stocker form was a 1.71. That was on a M/T 26x8.5 with 3.73's. I had all stock suspension. The lca were stock as were the springs. I had lakewood 50-50 and 90-10's up front. My car made power to about 5350-5400, due the the fact that I had the stock cam retarded 4 degrees and that moved the entire horsepower curve up 400 rpm. My website is gone. I got tired of paying for and ISP when i had free internet service thru work. So my webspace went away.
I've since sold my coupe and one of these day's I'll get another one and do it all over again....
:cool:
AL
well i like this tread it was today that i decided to get it into the 12's with stock heads/ intake / cam. I have gotten the idea from the other corralers trying too. BOLDSWORD you are my hero. But I am going to cheat and switch back and forth racing with my ET drags and the street tires. I am sooo excitied to get my transmission back today after THREE WEEKS of not having my stang. Im having withdrawls. Anyway, since i have driven my car last, i removed the back seat, all the brackets, sounds deadening, and anything else that was lying around in the back, spare tire ect ect. (100+ lbs) I also swapped my hood for the fiberglass cervini's (maybe 10lbs) and removed my front sway bar (15 lbs). I also gutted the stock h pipe and dumped my mac cat back. Any one wanna guess what she weighs now? I'm thinking right around 3000??? I'll be going to the track soon, after i get the idle figured out. I'll be "trying" powershifting, and running the e/t drags. What do you think i can get? I am planning on an offroad h-pipe, and headers next. Me and all the guys around here have a joke going about my car, because there is no reason it should be as fast as it is. But I guess it's becuase of the early Speed density thing. I can beat my friends 95 cobra with full exhaust, my other bud's 95 gt with CAI and Full exhaust and some ignition stuff, and my friend (brads5.0) 89 gt with longtubes, off road h, flowmasters, 3.73s with 255/16's, CAI, plugs, wires, coil, AFPR and some other little stuff. We just call my car the freak. Anyway, just trying to get some of my excitiment out to finally have my car back, and to ask for any advice from the others going for 12's with stock H/C/I, espeacially BOLDSWORD. Have a great day, adam
By the way, car has 190,000 :barf: . Ouch
wow, cleanLX, i just noticed your in mesa too. Actually, yeah, i will go the 26th. I was hoping it was open then, becasue tomorrow/ tonite is my 18th birthday, and i get to drive at the track finally. Do you ever go to PAvillons??? Email me sometime, [email protected]. I'd love to line up with another corraler. adam
Good thread!!!
This is my goal as well, I've been using Mr. Cosbys 'bolt-on' 12 Second ET Recipe So far I have: Densecharger aor kit, 75mm MAM, 65mm TB, BBK long tubes & H-Pipe, Flowmaster cat-back, underdrives, MK8 fan, Lakewood 70/30 struts & 50/50 shocks, Mega-Bite Jr. control arms, removed the air-conditioning
Still to do: wheels & tires, rearend, manual steering, electric water pump, tubular k-member & a-arms, move battery to trunk
Havn't been to the track yet but will come next spring
Heres how i ran several 12.8's. Off road H, dumps, 3.90 gears, nittos, fresh tuneup, removed a/c, pulleys, and all the free mods, and lastly a 100 shot of nitrous... with a 1.8 60 ft. Car can go faster if i could get it to hook good and get my bottle pressure up.
1 - 20 of 356 Posts
