I went to auto zone to get my engine light Checked , and the guy said to me the obd2 doesn't read , and he said check your fuse box , I have no clue what to look for and what to do. Help please!
power to the dlc
I have the same problem with my 95 Gt 5.0, it runs kind of ok when it's cold but once it warms up it runs bad. I tried pulling codes with a scanner but only got a connection error so I tried with a paper clip at the tester under the hood but got sone weird readings after a group of one flashes, I mean atleast 8 flashes I got a code 176. the check engine light does not go on when the key is on with engine not running either. Does this sound like a computer to you guys? My guages are also acting up. Any help would be appreciated.
sounds like a wiring issue
