1 - 20 of 24 Posts
I am looking for some advice on getting my first set of drag tires. A coworker told me that he has a hookup with Mickey Thompson and might be able to score me some steeply discounted tires. I have never bought drag tires before, but figure if I have the opportunity, why not?
Here are some details:
Weight about 2500 lbs
≈300 rwhp, about the same torque
Torque arm rear suspension
Can fit up to 26" diameter and 10.5" (275mm) wide
Will be running 15" diameter, 10" wide wheels
T5 manual transmission
Looking on the Mickey Thompson website, it looks like they have FOUR different tires that I can use
  1. Drag Slick
  2. Radial Drag Slick
  3. ET Street
  4. Radial ET Street
Having to change tires at the track is no big deal to me, but I am not an experienced drag racer, so a tire that is more forgiving of my lack of knowledge might be the best way to go.
Any guidance would be really appreciated. I am totally out of my element on this one.
26 x 9 slick if they make it. If not, 26 x 10.
I would run a 26x10 Hoosier QTP tire, probably one of the best hooking DOT tire that is not a slick.
If you are looking for a DR for street/strip then Hoosier DR are better then MT DR in my opinion.
If you are stuck on MT then get the 26x10 slick
Thanks Kurt. I am 'stuck' with MT if you could call someone doing me a favor stuck. Would you go with a radial or a bias ply? I know the physical difference, but what is the performance difference?
Thanks again.
Thanks again.
With your hp a DR would probably help the most for a double duty tire
26x10 slick. You won't have to "figure" out the tire as much as you would a drag radial. Drag radials can be difficult to work with when you have a 5 speed.
They have a lot stiffer sidewall than slicks. You can't launch as hard with a 5 speed. It takes awhile to figure them out. Plus, some usually don't hook as well until they are bald. You will be happier with slicks.
Slicks
I used MT DR for about 12 runs on my 00 GT 5 spd and the best 60' I could get was 2.102. That was on 275/40/17's at 12 psi. Spun hard off the line at any RPM, so I switched to 28/11.5/16 Hoosier QTP at 15 psi and my first time out cut .3 off my 60' times and dropped .3 off my ET at the same MPH as my personal best on DR. All of my 60' times were within .1 of each other.They hooked very well, no spin at all. My ET was improving .1 each run, launching at 3000-3500 with stock suspension. My prior best MPH on the DR was up to 113, but my ET and 60' were all over the place. My QTP just got better each run my first time out. Went 12.9, 12.8, 12.7, 12.6. I would definitely say run the slicks with the 5 speed, they are much more consistent. I would think the 26" slicks any width would be good for your power level. Even though I went with the Hoosiers, MT Slicks should treat you well. Let me know if you have any other questions, I'd be happy to share what has worked for me.
I love my ET streets! On track days, I bolt them up and drive there on them.(70 miles) Then cut 1.74 short times with only a 4500rpm launch. Going for 1.65's this Friday. 26x10.5x16
Discussion Starter #13
Cory, are you running ET Streets or the radial version? How big a difference is there?
carpdogg, great info, thanks a lot. How are slicks on the top end? I hear a lot about how they aren't really stable, but I have no idea what that really means!
Stability
I read on here a bunch too that slicks felt squirrelly and would sway as you got toward the end of your run, but that seemed to come more from the guys that were running 120+ mph. I got mine anyways and was expecting to experience some of that on my runs, but I didn't notice it at all. I am also running with my stock anti roll bars on, so I don't know if that helps with that or not. I could see how at higher speeds they would sway a little towards the end of the track though. Until you get up to those speeds I don't think you will feel that at all. I also didn't lose any mph between my best ET on DR vs the slicks. When I say slicks, mine are DOT approved, so they are similar to the MT ET Street. They ran the same mph. Hope this helps! That's awesome that you have someone to hook you up like that! Good luck with your selection!
Slicks will sometimes cause the rear of the car to sway. It will seem as though it is moving side to side. With my new M/T 28x9 slicks, I didn't notice much sway at all. I try to run the pressure as high as possible in order to keep the tire as stiff as possible and still hook well. The 26x10's will have a short enough sidewall that you may not notice much sway.
IMO. There is still only one ET Street on the market.
I guess when the ET STreet drag radials came out, alot of people started screwing up the names of the two tires...:rolleyes:
An ET Street is an ET Sreet IMO. An ET drag radial is just that.. a soft radial.
BTW.... There is a HUGE difference in the two. With a manual tranny, the ET Street would be the better choice.
Discussion Starter #17
Thanks again Cory. Can you tell me more about the differences please. Why would I be so much better off with an ET Street versus the radial.
Thanks.
There seems to be some confusion on the Mickey Thompson lines.
An ET street is a bias ply “DOT” approved tire that is really only good for track duty. Because it’s bias ply, it can get squirrely on the big end of the track if you use radial front tires. This is because they have different characteristics and sway differently at speed. Obviously the faster you go, the more noticeable it will be.
The ET street radial is the “DOT” approved drag radial tire that is suitable for the road and track. It’s still not advisable to run them in the rain, but they will last ~5k miles if you drive them on the street.
The bias ply ET street will be better for a manual shifted car because it's sidewall will wrinkle more and absorb the shock seen with high rpm clutch dumps. They also tend to be easier on all of the drivetrain for this very reason.
In the end, if you want a tire for track duty only….the ET street is probably your best bet. You can drive it to and from the track…but I wouldn’t do much more than that. The ET street radial will be the better all around tire. It won’t allow you to do the high rpm clutch dumps the way the ET streets will…and when you hook hard, will be much harder on the drivetrain.
From my understanding, if you want the best of both worlds….go with the 15” et street radials with the 26inch dia. The sidewalls will give you the most wrinkle while still giving you the stability of a radial tire.
Discussion Starter #19
Great advice, thanks Millhouse. I am thinking that the radials may be my best bet since I am going to try the Maxton mile (1 mile land speed race) as well, and the idea of top end sway at those speeds is a bit unnerving.
Plus, I am really a rookie at this and so I don't think I am going to be held back the tires.
carpdog- do u run tubes?; heard u can run tubeless on some tube-type tires (M/T ET streets) as long as u don't run the pressure too low (so the tires don't spin on the rims) & u must check pressure frequently due 2 increased air seepage.
also,u went from 26" diameter m/t drag radials to 28" diameter hoosiers; do u think the diameter change contributed to the performance difference? also, same question going from rim diameter 17 to 16. (more wrinkle, better traction with a smaller diameter rim?)
1 - 20 of 24 Posts
