1 - 20 of 162 Posts
Hi guys I wanted to compile a "quick reference" chart of the most common nitrous spark plugs for 5.0 and 4.6 Mustangs. Here is what I have gather thus far....
5.0
Stock E7 heads:
AUTOLITE
stock--stock 25 (5) [14m, .460 Reach, 5/8" Hex]
1 step colder--24 (4) [14m, .460 Reach, 5/8" Hex]
2 step colder--23 (3) [14m, .460 Reach, 5/8" Hex]
-----AR133 (3) [*recessed tip, racing plug]
-----AR132 (2) [*recessed tip, racing plug]
-----AR131 (1) [*recessed tip, racing plug]
NGK
stock--(UR45) 6945 (Heat Range - 4) [14m, .460 Reach, 5/8" Hex]
1 step colder--(UR55) 2248 (5) [14m, .460 Reach, 5/8" Hex]
2 step colder--(UR6) 7773 (6) [14m, .460 Reach, 5/8" Hex]
-----(R5673-8) 3249 (8) [*recessed tip, racing plug]
-----(R5673-9) 3442 (9) [*recessed tip, racing plug]
-----(R5673-10) 4050 (10) [*recessed tip, racing plug]
GT40 Heads:
AUTOLITE
stock--765 (Heat Range - 5) [14mm, .708 Reach, 5/8" Hex]
1 step colder--764 (4) or 104 (4) [14mm, .708 Reach, 5/8" Hex]**
2 step colder--103 (3) [14mm, .708 Reach, 5/8" Hex]**
-----AR473 (3) [*recessed tip, racing plug]
-----AR472 (2) [*recessed tip, racing plug]
**The difference between the 764 plug and the 104/103 plug is the thread. The 764 plug is a half thread whereas the 104/103 plug is a full thread. The full thread plugs are duplicates of the half thread plugs in every other aspect, they both protrude the same amount into the combustion chamber.
NGK
stock--(TR4) 3754 (Heat Range - 4) [14mm, .708 Reach, 5/8" Hex]
1 step colder--(TR55) 3951 (5) [14mm, .708 Reach, 5/8" Hex]
2 step colder--(TR6) 4177 (6) [14mm, .708 Reach, 5/8" Hex]
-----(B8EFS) 1049 (8) [*recessed tip, racing plug]
-----(B9EFS) 1085 (9) [*recessed tip, racing plug]
TFS, Edelbrock, and AFR Heads:
[14mm, 3/4" Reach, 5/8" Hex, gasket seat]
AUTOLITE
1 step colder--3924 (4) [*recommended starting point]
2 step colder--3923 (3)
-----AR3933 (3) [*recessed tip, racing plug]
-----AR3932 (2) [*recessed tip, racing plug]
-----AR3931 (1) [*recessed tip, racing plug]
NGK
1 step colder--(FR5) 3686 (5) [*recommended starting point]
2 step colder--(BKR6EY) 3696 (6)
-----(R5671A-8) 4554 (8) [*recessed tip, racing plug]
-----(R5671A-9) 5238 (9) [*recessed tip, racing plug]
-----(R5671A-10) 5820 (10) [*recessed tip, racing plug]
MOTORCRAFT
1 step colder--AWSF22C
2 step colder--AWSF32C
4.6
MOTORCRAFT
stock--AWSF-32C (copper)
1 step colder--AWSF-22C (copper)
2 step colder--AWSFA-12C (copper)
AGSF-32C--FRPP heads
NGK
stock--TR-55/ 3951
1 step colder--TR-6 4177
1 step colder--NGK TR6
1 step colder--NGK BR6EF (Non-projected, resistor, v-groove copper)
2 step colder--NGK BR7EF (Non-projected, resistor, v-groove copper)
2 step colder--BP7EFS [PN - 3526] BR7EF [PN - 3346]
2.5 step colder--R5724-8 [PN - 7317]
3 step colder--R5724-9 [PN - 7891]
4 step colder--R5724-10 [PN - 7993]
AUTOLITE
stock--764
1 step colder--103
2 step colder--AR94
3 step colder--AR93
4 step colder--AR92
CHAMPION
YS-59C
DENSO
stock--IT16
1 step colder--IT20
2 step colder--IT22
3 step colder--IT24
Please feel free to correct any errors I have as well as give me part numbers to add. Any help is appreciated!!! I'll be updating this repeatedly
Discussion Starter #2
On those 5.0 plugs, its going to depend on the heads. None of those plugs you mention are for stock E7 heads. Autolite 25 are stock, 24s 1 step colder, and 23s 2 steps colder.
On the 4.6s, the NGK TR55 are stock heat range, TR6 1 step colder.
Tony
Thank you LXH89, that's what I was wanting. Corrections and additions to the list. I think it'll be helpfull........
Any more suggestions????
The NGK R5671A-9 is a great nitrous plug. It has a recessed electrode and a shortened ground strap to help avoid detonation. It comes in other heat ranges, with a nine being about 6 or 7 ranges from stock. This plug works on TFS, Edelbrock, and AFR heads. Anything that uses a long reach plug. I have the number for the stock heads as well, but I will have to look at the box later to get the number.
For Non-Projected tip plugs on the 4.6 use the following:
NGK BR6EF - 1 Step Colder (Non-projected, resistor, v-groove copper)
NGK BR7EF - 2 Step Colder (same spec as above)
Tony
Awesome and awesome adding those number right now
mustangmichael get back to me whenever you can with those number
LXH89, once again thank you
GT 40 Heads run a wierd plug, I will check when I get home to see what they are. I have one ported head sitting in the basement, and I can screw a couple of plugs into it to see which one it takes.
Discussion Starter #12
Polygon I'm not totally sure, that's why I wanted everyone's input. Anyone........
Hey no big deal mikey, I'm just trying to contribute.
When I got the nitrous kit in, the shop originally sold me Autolite 764's (the plug for the GT-40 heads) because I asked for them by name. When I wanted to go a step colder, they looked it up and discovered that Autolite doesn't make a range colder for the GT-40 heads. They told me to go with the Motorcraft AWSF22C.
Discussion Starter #14
No it's GREAT that you are contributing; I'm hoping more will toss in their part numbers!
Discussion Starter #15
Edelbrocks can use the autolite (not light) 3924/3923 as well.
Discussion Starter #17
Jay thanks for the input, and thanks for the spelling correction!!
HAHA!
Discussion Starter #18
Up to the top for some more additions to the list..........
I use a NGK TR55 and TR6 in my 93 Cobra GT40 irons. I believe the Autolite 103s are 1 range colder than the 764s.
Its been a while since I ran nitrous, but I think I'll be getting another kit soon so I better start remembering. :)
Discussion Starter #20
Cool, thanks for the input!
1 - 20 of 162 Posts
