I have a 94 gt I'm getting ready to install my turbo kit it's a boost brothers turbo kit with a 70mm mast power turbo. My motor is completely stock .. Here are some questions I need help with
- do I need a booster pump with a 255 pump?
( I'm running 42's with a Pmas pro tube)
- should I use a msd btm or just a 6al
I'm hoping to pick up a Anderson Pms
-I have read different things about what I should set my timing at I just wanna know what to adjust everything to (fuel pressure etc ) just until I tune it I'm looking to run 7-8 psi..
is your 255 pump a high pressure pump designed for boost, or just the standard pump?
