I know this has been asked before but im new so please bare with me. Can Iput a 255/60r15 mt et street on a fox with15x8 5.5 in bs draglite without fender mods
Nothing a big f$&@ing hammer can’t fix on the inner wheel wells. No quad shocks. May have to roll the fender lips, which is easy using the baseball bat method.
That being said, you should be ok with the fitment. Just throwing out ideas.
What is the largest 15 in tire i can run with no modifications
With absolutely no modifications (quad shocks in factory location) I was able to run a 245/60/15 Cooper Cobra on the stock 15in. ten hole rim.
I currently use a 275/60/15 Nitto NT555R Drag Radial on a 15in. centerline auto drag. I previously used the same tire but sized in 275/50/15. Still was able to use KYB quad shocks with both tires, although I did have to flip the quad shocks and tap the fender lips "a bit" to prevent rubbing.
A larger tire will fit under there, but I'll probably have to remove the quad shocks and start banging at the inner fender wells.
