Hey all,
So as the title states, I am needing help with a crankcase ventilation issue. To get started, this is not a track car. This is a street driven car, so I am not looking for solutions designed for racing applications. I am hoping for something fairly simple, that works for what I use the car for (occasional cruising, she is not a daily) Anyway, I recently installed a Paxton Novi 1220 SL on my 93 pushing 6lbs of boost. Today, after giving her WOT a few times, I noticed oil weeping out of the dipstick. This is not a significant amount of fluid here, just some wetness on the outside of the tube, and a few droplets that caught my eye on the spark plug wires. We are not talking about blowing a dipstick out or anything. Clearly though, my crankcase it getting pressurized. So you guys have all the details here, compression numbers are all within normal range of each other, vacuum pressure holds true at negative 17-18 psi at idle, and spark plugs look clean. So, I am not thinking this is blowby (although I am a newbie so what do I know). As she sits currently, she does have a PCV setup on a 99 explorer intake. The PCV was bought new recently at Autozone, and the setup is run like the Explorer which originally owned the intake, with one line coming off the PCV valve connected to a fitting which allows two lines to be plugged into two ports on the plenum. Also, as the instructions for the SC install stated, I removed the line from the TB to the oil filler tube, and connected a line from the oil filler tube to the intake housing surrounding the air filter, with an inline filter (NAPA GOLD Filter 3033). All parts for this setup came with the kit. This was not just something I rigged up. I would have thought this would be enough ventilation, but this setup does not seem to be working well enough. I am worried about my main seals here. I already have a rear main that leaks despite changing it several times, and I don't want to make it any worse. Also, just as a side note, I have a small weeping leak from the lower intake right behind the thermostat housing where you apply the RTV in the corners. This is probably just me again being a newbie and doing a crappy job when I installed the lower intake, but I am wondering if maybe the pressure is making that one worse as well. One thought I had was installing a breather cap in place of the oil cap, in addition to all that has already been done. The marketing picture that advertised the SC on the AM website where I bought the SC, had it like this (breather cap plus line running from oil tube to air filter housing) Can I do that? Would it help? If not, what should I do? Thanks for any help anyone can provide.
