141 - 160 of 160 Posts
What is the maximum outside diameter the water pump pulley can be? I have aftermarket pullies, not sure how much they vary from stock.
You wont have any issue with clearance. It would have to be a huge pulley to be any problem.
10-4 Pretty sure I am going to need one soon but was curious because your first post says.
The larger than stock underdrive water pump pulleys will not work and they will hit on the bracket
Will probably be in touch soon. Thank You.
Front end/pullies and some other misc stuff is at powdercoat at the moment. I did get a measurement of 18.84 circumference or 6 inch across.
