1 - 1 of 1 Posts
Vendor
Hi everybody!
I proudly inform you that we offer some new Mustang parts and accessories, such as
1) BAER® - Extreme Plus Brake System
Extreme Plus Brake System by BAER includes 6-piston monoblock calipers for the front AND rear, lightweight two-piece rotors, stainless steel caliper hardware, and pre-loaded ceramic brake pads.
2) B&M® - Performance Street and Strip Automatic Transmission
Performance Street and Strip Automatic Transmission by B&M is a complete ready to run unit for high performance street and mild strip use. The transmission provides firm shifts and features a standard shift pattern, these are the finest available for street or strip use.
Features:
- Rebuilt front pump
- New special bellville spring
- Five clutch direct drum
- New low roller clutch
- Four pinion front carrier
- Fully recalibrated valve body
3) Mallory® - Ford Mustang 1998-2010 Ignition Control Module
Ford Mustang Ignition Control Module by Mallory ushers in a whole new era in performance ignitions. The Firestorm module provides an output to the ignition coil to fire the plugs, of course, but that’s where the comparison to a conventional CD ignition amplifier ends. Adaptable to 4-, 6-, or 8-cylinder engines, the Firestorm also provides a rev limiter, tach output, manifold pressure boost retard and many other functions.
Features:
- Full-retro distributors with points if you need them
- Integrated solutions for breakerless distributors
- Replacements and upgrades for virtually every vehicle with a distributor
- Custom vacuum and mechanical curves
- State-of-the-art ignition components
4) LUMEN® - 22" Nite Rider Multicolor LED Scanner Bar
Add original and unique visual impact to your Mustang and increase nighttime visibility when you're alone on dark roads with the universal 22" Nite Rider Multicolor LED Scanner Bar by Lumen.
Features:
- Over 20 different scanning operations from traditional "Knight Rider" television show slow pulse to rapid strobe flashes
- All scanning programs are available in 7 different colors that include blue, green, light blue, red, purple, white, and yellow
- Includes hand held remote control for full functional control away from the vehicle
- Speed of light pulse across the width is adjustable
- Measures 22" in width x 0.55" in height
- All standard wiring and hardware are included along with instructions
1 - 1 of 1 Posts
