1 - 1 of 1 Posts
buying an 02 V6 vert.
already have a LY6 6.0, cam change, LS3 intake etc. I don't have a harness/ECu yet so not committed whether I will be running DBW or DBC. I suppose a pedal assembly from a Tahoe or the like will fit in stock position?
My main question is, where does the PATS system cut off power? If I keep the ford computer in place with ford key, but run a dedicated LS fuel pump wire, will I have power?
On the ignition, I assume to hook this up like my sniper system on my windsor I would need hard negative and positive plus a hot key on/crank. How does the PATS system affect this? Can I simply take the ignition hot key on?
1 - 1 of 1 Posts
