I heard if you run aerospace front brakes that you need new brakes lines. Is it the same with strange front brakes? I just picked up a strange front brake set up and want to have everything I need before I rip it apart,
Yes you will need new lines as the calipers have a 3 an fitting on them.
Do you know where I can get the lines and fittings I need, how much etc? thanks
Its been a long time since I did it, I used some earls adapters for the hard line on car then after I had the new brakes on the car and figured out how long of lines and went to a local circle track shop and picked up the 3 an brake lines. Sorry I cant be more help.
Thanks for the help, I appreciate it, did you measure the exact gains from doing the brake swap or did you do them when the car was down?
