85 MUSTANG GT STREET/STRIP CAR - FROM: $5500 OBO[/COLOR]I’m selling a very well maintained 3rd owned mustang hatchback.
It is in good condition for its year.
-INTERIOR: decent condition
-EXTERIOR: needs minor body work.
-NO A/C
-ONLY 3000 miles on new motor and clutch
I have invested well over 15k in this car so serious inquiries only. I would love to keep it but I need the money.
ENGINE: 347 stroker shortblock built by Kotzur, probe forged pistons, scat lightened crank and rods, dss main girdle and windage tray w/ cnc ported afr 185 heads, comp cams push rods, scorpion 1.6 roller rockers, ron anderson n-91 camshaft and high rev valve springs, edelbrock victor jr intake, holley 670 street avenger carb., edelbrock victor water pump, bbk long tube headers, 93 cobra water pump pulley,...(continued)
DRIVELINE: tremec 3550 5 speed trans with mcloed sfi bulletproof bellhousing, ford racing flywheel, clutchmasters stage 4 clutch and pressure plate, pro motions shift fork, steeda clutch quadrant and cable and firewall adjuster, ford racing driveshaft, 8.8 rear end (had a 7.5 inch originally) with 4:30 gears, hardened axles ,and all new bearings, with less than 3000 miles
IGNITION: msd digital 6 ignition controller, msd probillet distributer, msd/hvc coil, Ford Racing plug wires & auto lite plugs, auto meter 5 inch monster tach with shift light,...(CONTINUED)
SUSPENSION: maximum motorsport caster camber plates & lower control arms, eibach drag launch springs,...(CONTINUED)
There is a lot more that I’m forgetting but u can call me and check it out. This would make a perfect drag car; it ran 11.90 with drag radials and a 2.0 60 ft. so this car has a lot more in it. The motor is set up for nitrous but has never been added. I would like $5500 for this but I’m open for negotiation.
This is pretty much a sound clip/video for you.
http://tinypic.com/player.php?v=oqg1s4&s=5
