I am getting my coupe ready for paint and need to remove all the old garbage weatherstrip from around the windows which means I need to roll them down. The problem is my car has the entire wire harness out at this point. Would it be as simple as running a ground and a 12v to the window motor itself in order to get the window down? If its more involved, any tips on how to get it done? Unfortunately electrical is not my strong point. Thanks guys
a battery is all you need
changing polarity changes motor direction
Lol I recently had the same problem. I pulled the door trims off and used an 18v cordless battery and some bits of wire
