Car has 140,000 and I track it a lot so I think I am going to change the front hubs before something happens. I want the best/strongest available in a stock replacement. What does everyone suggest and what size in the spindle nut and torque spec?
Super Moderator
Koyo brand are about the best you'll get, available at any parts store. I like to take them apart and re-grease them with high performance grease like Redline. Spindle nut is 35mm, torque spec is something like 250 lbs. You're not technically supposed to re-use the nut, but everybody does. On a side note, it blows my mind you haven't had to replace yours yet. I'd almost be inclined to just buy a new one as a spare and wait til yours actually start to go, they'll give you fair warning when they do.
Koyo brand are about the best you'll get, available at any parts store. I like to take them apart and re-grease them with high performance grease like Redline. Spindle nut is 35mm, torque spec is something like 250 lbs. You're not technically supposed to re-use the nut, but everybody does. On a side note, it blows my mind you haven't had to replace yours yet. I'd almost be inclined to just buy a new one as a spare and wait til yours actually start to go, they'll give you fair warning when they do.[/QUO
As of right now they are smooth and tight. I just keep thinking that they can't last too much longer. I am just afraid that one will come apart while on track. Maybe I'm paranoid because I had a wheel break a few months ago and before that a strut broke almost in half. If you think they will give me plenty of warning maybe I'll wait.
Buy a spare. I take a spare Koyo front hub pre-loaded with ARP extra long wheel studs. You will need a 250 ft-lb capable torque wrench and a 35mm socket. Getting the old one off will take an air gun or at least a breaker bar.
There are two types of spindle nuts. The Dorman nut is a few bucks with a crush sleeve. I prefer the Motorcraft nut which is made up of a number of crush washers caged in a housing. Maybe 3X more than Dorman at $15 or so.
MFE. Are they easy to take apart or is it somewhat involved? Curious
Super Moderator
