I just finished my turbo install on my stock 5.0, AOD car. I have a moates QH with a base tune setup for my application. When I first started my car everything seemed to be in order with idle AFR around 14.2. I have taken the car on a back road by my house to make a few part throttle runs to check everything was ok.
I started having oil blowing out the dipstick first so I have been trying to work out a solution for that. After a few more part throttle passes for some reason my car is trying to run lean at start up and eventually dies.
Any suggestion where to start looking?
not sure about the start up and stall problem just yet. but on the oil issue did you remove the tube that goes from the throttle body to the oil fill neck? what did you do about the pcv vlave
