I am having problems with the car turning up under load on the street and the dyno At 3500 It acts like it is blowing the spark out
So I put a 6AL and gaped the plugs down to .25 Still the same thing
Car is making good power till it cuts out
It will Free Rev fine just not under load
Stock 95 Cobra Motor
67mm Turbo
Turbosmart Boost Controler
10psi
6AL
Diablo Chip
255 pump
60lb inj
LMAF
any Ideas?
What's the AFR, fuel pressure, timing, and boost when this is happening? What's the volt reading on the MAf as well; it may be getting clipped?
Formerly eades5.0
Which plugs? Maybe try gapping them even tighter to see if the condition changes (.018-.020) just for testing purposes.
TFI module?
