1 - 14 of 14 Posts
Turbo build
Looks like I missed a lot . sorry, Im tired.
97 4V cobra 5 spd
Im at the end stage of my build. Only things left to do are find a home for the oil filter. then run the fuel lines.
i keep the AC and the PS. It dosent look like the back portion of the exhaust is going to work. Im going to have to take it to a shop for that.
Im thinking of making a bracket and moutning it just behind the D/side motor mount in between the K menber and the trans.
Any pics or Ideas would be a big help.
I put mine up under the horn inside the fender. i can just pop my fender liner and change filter/access it pretty easily. i used all the oil line it came with though and it wraps around kinda funky. but it works.
I mounted mine to one of the bell housing bolts. It puts the filter right beside the drain plug. Ill post a pic tomorrow before I unbolt it to pull the motor.
Trans bellhousing , works great. Here is mine
Different cars i know but i just used a smaller filter in the stock location did not want to re-locate the filter route oil lines etc...works great for me...
^ have to relocate on new 2v & 4v ff kit.
Discussion Starter #12
1 - 14 of 14 Posts
