I not sure where else to ask this but,
im building a 302 for my bronco 2, i have a complete explorer motor,
and two of those cheap ebay turbos
heres a link to the specs.
I want the motor to have alot of low end torque, and my thinking is 2 small turbos would be just the ticket, i plan to run 8lbs of boost too.
ive been doing alot of research but cant seem find a good answer.
would these turbos be big enough(supply enough air volume) for the 302?;
keep in mind im not going to be reving past like 5k
would the stock 19lb injectors be big enough or do i need 24lb?
im going to be running megasquirt, so theres no dicking around with stock computer
and dont rip on me for the ebay turbos,they were free!
thanks
the biggest issue i see with those turbos is the internal waste gates.. but for what your looking to do, you should be fine.
no way will the 24lb injectors do what you need them to do. id say atleast a 42.
if all your looking for is torque, then those turbos should do the trick, and spool up pretty quick. weld the waster gates shut and add some external gates to control the pressure better.
