hey guys i have a 393 windsor that i am putting a blow thru setup in i was wondering if u guys would know what type of fuel pump i will be needing to run so it does not go lean during boost i will be boosting at 10lbs of boost with a 76mm turbo. thanks alot in advance guys
Firgure out your engines break specific fuel consumption
then call up a company like weldon, aeromotive...etc. and they should be able to hook you up. Remember, you are also going to need some kind of an adjustable fuel pressure regulator that references boost, I would also highly recomend running a return style system if you plan on running your car on the street for any length of time.
