What wire do I splice into the fuel pump wires to have my bpautomotive engine harness ( stand alone harness ) kick on the mustang fuel pump. My engine harness has one wire I need to splice into the stock mustang harness to kick on the pump. I can't figure it out. Any help would be great thanks.
Stats
1993 mustang lx 4 cylinder
Pulled the engine harness out
Kept the body harness in
Have everything hooked up but the fuel pump
Discussion Starter #2
Got the answer.
For the 4 cylinder the wires to the pump are on the right side passenger kick panel.
Green wire with yellow stripe. As for the wire to get 12v on aux and crank you have
To splice into the red with green stripe under the dash. You can get to it from the ignition.
Thanks for the help.
Got the answer.
+1 I was just about to help you out
