K, car has:
Bilstein Struts
D&D K-member and arms
MM coilovers and CC plates
Need to get it aligned, but before I take it in I sense a problem coming...I had to kick the CC plates all the way IN to even get close to neutral camber. I suspect they still need to come in, but there is no room left in their slots. What do I need to do to fix this?
With the MM CC plates you should have plenty of camber adjustment range even if the ride height with the coilovers is set up really low. Unless the front track is narrower with the D&D K-member and arms but this seems unlikely.
In fact, I had the exact same setup on my car for a while (except I had Tokicos w/ the coilovers) before I swapped out the D&D K-member and arms for the MM stuff and had no problems with not being able to get the camber in spec.
