I already have the axles for the rear end, but i dont know what year and model of cars i can use to convert the front end to 5-lug, i know u need the front spindles, rotor, and brake caliper. can u guys help me out? thanx
I also forgot to add that its a 1992 mustang, if that makes any difference???
[email protected]
if your gonna use aftermarket wheels you can get away with 88 lincoln mark 7 rotors they use the same bearing and seals as mustangs they go right onto your stock spindle. But if your using wheels like cobra wheels then you have to use 94-98 front suspension. I used just the spindles and brakes but i had to use a spacer for the ball joint. Ive heard you have to use the struts too but i got away without them. goodluck if you have any more question just email me [email protected]
almost forgot, if your using a wheel like telestars or welds you have to use the lincoln rotors unless you buy those expensive xp's to space over the calipers.
