1 - 19 of 19 Posts
Ok, with 4 cyl. springs, 90/10 shocks and deleted swaybar up front. Stock springs with air bag in right side , 50/50 shocks and after market control arms, stock swaybar for the rear the car when 1.54, launching at 5500 rpm.The upper arms are non-ajustable style.
How can i improve my 60 feet ?
Does ajustable upper arms can help me by seting the pinion angle ?
How about an antiroll bar and which one ?
Maybe something else ?
Check out these for the anti-roll bar and uppers. Both come highly recommened.
http://www.baselinesuspensions.com/
http://www.teamzmotorsports.net/index.html
My set up is tube k-member and arms, strange dbl. adj. struts, coil overs. Baseline uppers and lowers, strange dbl. adj. shocks. No anti-roll bar yet, this car hasnt seen the track yet. Most people have the same or close to what im using.
Take some weight out of the car, that should help your 60' foot.
dosnt sound like it spins a whole lot, maby a slight bog after the spinning. try a few more psi in slicks to elliminate the bog and see what happens. Sometimes a dead hook can hurt the sixty via a a bog but a lil tire spin keeps the motor in its power band.
90/10 struts and 50/50 shocks. These are generic as a cylinder head company that says there heads are 225cc and flow xxx cfm. It is bull#### and generic and used to sell to a large crowd. Strange sells a decient adj. shock and strut if you are on a budget.
Discussion Starter #17 (Edited)
Right, but you want decrease your 60ft time. You have a spool in the car? Car is a stick?
Cobra diff with the carbon clutches and G-force T5 launching at 5500. I wanna keep the car as streetable as possible..
I've installed 90/10 and 50/50 this summer...:crying:
hijacking...
For the rear spring setup on a drag car, do you guys recommend the 4cyl. springs, V8 springs or a set of Moroso or Eibach rear springs?
I'm installing TeamZ lowers, Strange shocks, I have a wolfe anti-roll bar already in and the UPR UCA. I am replacing the UCA with the Team Z piece when I sell some of the crap laying around.
I just need to figure out the rear spring.
Thanks and sorry for hijacking, but this along the same topic and hopefully it will help someone.
David
1 - 19 of 19 Posts
