here is my combo:
91 coupe 306 kb pistions
edelbrock performer heads and intake
comp cam 544-544
24lb inj. and mass air, with 70mm tb
equal lenght headers,h-pipe, 2 chambers flow masters
world class t-5
3.73 gears
upper and lower control arms
this is what i ran at the track
7.87 at 89.887 mph with 1.69 60 ft. is this good for my combo?
also what should it run with a 150 wet shot?
any info is appreciated. thanks
Cam is a little small, put the 19 lb injectors back in for N/A and then MAYBE switch to the 24s when you get your nitrous kit. What kind of tires were you running on?
26x 10.5x15 mt et deags leaving at 5500
how is this cam small based only on lift numbers? why would it run better with 19lb. injectors?
times look good to me, with a 150 you might be able to squeeze out a high 6.
