1 - 12 of 12 Posts
We need a little more info bud. RPM capabilities, trans, gear, power wanted, ect. ect......Stock block??????
68 block, 5-speed car 3:55's, Don't want to rev real high maybe 6200rpm. Want it to have a mellow idle Looking to make around 500rwhp
Any cam in the low 220's on duration and low 500's on lift. I would be willing to bet money that a stock 5.0 cam and 1.7 rockers would be very close to any cam below 5800 rpm in hp. Since it is a stick car I would keep it as small as I thaught I could. Bigger than stock cams always seem to make a stick car lazy will driving stop light to stop light in traffic. Just my opinion I am no expert.
see lots of folks making silly power on stock cams OR the F Cam...:shrug:
http://www.lsmeng.com FTW
F cam is good for 302. If you have not done the 347 yet ..... DONT.
Just rebuild it has a 302 with an F cam and some good heads.
You will easily break the block with that combo. Hit 500rwhp at 12psi or so.
6,000.
For your wants.
you need 302 with stock crank, forged rods and pistons
TwistedWedge Track Heat, AFR 185 or similar head
F cam with Holley Sys-II intake with a 67-70mm turbo.
Pull hard to 6,000 rpm, idle nice with little bit of thump
make 500rwhp at 12psi or so.
i ran a E cam for 2 years, worked pretty good. Def cant go wrong with the F cam
1 - 12 of 12 Posts
