1 - 1 of 1 Posts
I got this old vert with lots of extra parts and running.I broke the reargear at the track but I have two different 8.8 rearends one has 3.55 one has 4.10.2500 takes the whole car I got an extra top in good shape.the one on it is black and not too bad but the hinge that has the hook on it broke It still latches down just not as far.that is why I got the other top it is light tan looking needs cleaned(I cleaned it once but it has been sitting in the garage)anyway the car hasan 83'351block 030 over coated hypers 10/10 crank,comp magnum 292/540 lift.or so not sure anymore.resized rods with hardened bolts,fluid damper(street not sfi)SFI flexplate,ported(20 hours!) 76 302 heads with 1.94/1.60 pbm undercut stems.PBM roller rockers 3/8stud and guideplates 5/16 pushrods..the intake is RPM but I think it has been on an angle milled motor cuz it leaks just a little water at the bottom front of the engine.even with the black gaskets.I have another rpm intake for 50 and the old one back.It has a 750 (3310) vacume secondary that I rebuilt and cut the choke out like an HP.It has 1 3/4 longtube macs with twobolt flanges ,short Hpipe and spintech mufflers.(sounds Awesome!) C4 rebuilt a year ago(same as motor)with shift kit,4500 stall champ converter,and Z gate shifter.the stall is perfect for the car I think.With 4.56 gears and stock suspension other than the welded in subframe connectors it ran 7.46 in the eighth mile at 90 mph and a 1.61 60 foot.I could have gotten 7.30's out of it with some tuning.too busy to race much now so whatever...It also has a flaming river manual rack,100 amp chrome one wire alt.,electric waterpumpdrive,mk8lincoln fan,saleen wailtail,nice black dash,85 red escort GT buckets.It runs and drives when I get the rear end in it.( I can't figure out which rear I want to put in it)you help me decide!OH yeah its also got MSD 6AL, Accel supercoil,stock mech.fuelpump with holley reg.and earoquip lines here and there.Let me know what you got (trades,partials,money)I got all kinds of mustang stuff (doors,fenders,t tops,projectcars,motors,trannys,turbo stuff,2.3's,94 stang,81 coupe,83 capri,88 shortbed ranger.,cyl heads blocks,you never know so just ask.thanks
1 - 1 of 1 Posts
