1 - 13 of 13 Posts
i may change to carb as i posted earlier
does anyone have a set up close to mine CARBED ?
331
AFR 185'S
11:1 COMP
COMP 242 @ .050 .555/.565 LIFT
5SPD
3.73'S
3200 #
113 mph 1/4
MINE MADE 340 RWHP-355FT TQ
if i can make more power carbed N/A then thats the way i wanna go ...thanks
That is one tiny cam you have. I run 111 with 306 CI and P heads, I think you need to do some tuning and practice practice practice. Also ditch that 3.73 for a 4.10 or 4.30, are you running on slicks, DRs what kind of tire and what is your ET?
THE CARS ALREADY BEEN TUNED
the car ran 12.50's w/ 2.3 60' @ 113 ..the track was very slick ...and i was running 275-40-17 M/T DR
I have a carbed 331 I have been 10.98 at best in good air but runs 11 teens in decent air like summer/spring. You need a 4.30 gear in the rear. You have the mph to run 12.teens
What size exhaust, what type of efi intake, size injectors and mass air meter?
my car has a 2-1/2 mac , bbk shorty's ,
trick flow track heat
36 lbs inj
80mm mass air
70mm tb
I had that same exhaust then switched to mac 1-3/4 with 3" collector with a 3" pro-chamber and 3" mufflers picked up 17 rwhp.
had 30 lbs inj
76mm mass air
75mm tb
Discussion Starter #11 (Edited)
My efi 331 with 185's made 370 rwhp with that same cam.
i know my headers are hurting my numbers ..i have buddy's that gained 15 rwhp by changing to 1-3/4 long tubes
so you car made 370rwhp ? thats what i think my car should be making
what was the setting on the dyno ?
uncorrected ?
corrected?
SAE ?
A friend of mine runs a carbed 331 actually a 327 not bored. He runs in the 120'mph range and 11.26 et's. He put down 397rwhp in a 92 coupe full interior car.
1 - 13 of 13 Posts
