1 - 11 of 11 Posts
I just got my new turbo in for my new motor setup. Its an Borg Warner S400 75mm going on a low compression 358W. I had a Master Power T70 on my 302. Needless to say, this things pretty big. More turbo than Ill ever need. :banana:
damn i never thought a 75mm would make a 70mm look that small LMAO
i was looking to turbo my new set up but have no idea at what rpm an s400 will spool up any idea??? or should i go smalleR?
dart 363ci 3.4"stroke 9.5comp
vic jr intake
750blowtrue
vic jr heads (stock)
custom cam
tr-3550
you know, im not real sure. I just wanted it for the performance aspect of it. My car is a street car but sees a lot of track use so I went for it. I figure on the transbrake, itll spool. You should make some kick ass #'s with it if you get it.
Turbo weighs in at a hefty 42lbs and it does make the ole 70mm look tiny!
thanks
Brian
Wanna sell the 70??
i may be but gonna see if i can make the S400 work with my old setup. If it wont work, im gonna sell the whole kit (B&G). If it does work, ill be selling the 70mm with the .96 and .68 housings.
thanks
Brian
ill keep everyone updated on the kit or the turbo by itself. My buddy really wants the kit if i dont use it so not too sure if ill post it for sale or not. But, ill be sure to update.
thanks
Brian
1 - 11 of 11 Posts
