201 - 214 of 214 Posts
'87 Cougah 428W - ⚡Cougar7.0⚡
Cracked plug, valve float/bad adjustment, broken spring, ECU smoking crack.
Discussion Starter · #204 ·
Changed to fresh plugs. No change.
1) rewrite the calibration to the chip.
2) disconnect battery to reset eec.
3) start car and drive to see if any better.
4) Drive around listening to lil xan
definitely worth a shot!
Discussion Starter · #208 ·
I’m leaning towards it being ignition related rather than fuel as it happens precisely at the same rpm regardless of light throttle or heavy throttle. Seems the only ignition related part I haven’t thrown at it is the coil. Is it possible for a faulty coil to act up this way? I thought they either worked, or they didn’t.
log
maf
load
02 voltages
short and long term trims
LAMBSE 1 and 2
rpm
spark
TPS
wide band if you have it
Discussion Starter · #210 ·
I have it logged (no wideband though). Not sure what I’m looking at/or for. I never got into the nuts and bolts of tuning, and didn’t have the time which is why I paid for remote tuning. Not sure why he isn’t able to take a quick look to lead me in the right direction.
I’m using Tuner Pro RT for logging.
holidays?
email me the file
Discussion Starter · #212 ·
Very kind of you to take a look. PMing for email.
Thanks.
Not sure if it has been covered, but are all the grounds solid?
Does voltage drop at that rpm?
he must be on vacation or something, i Iposted a log from a test he wanted me to run and he hasn't got back yet either.
