1 - 8 of 8 Posts
Exactly what the title says... the hatch lock pops, and thankfully the hatch stays down, but bounces around, sucks air the wrong way, etc... all the way down the track. I doubt I'm losing ET, but this needs fixin.
I've tried adjusting the latch catch (maybe wrong term), but to no avail.
Any Suggestions?
David
Do you have subframe connectors and/or cage? Sounds like excessive chassis flex to me.
yes, full-length subs and a 12-pt cage, all tied in. the car is pretty stiff... that is a good guess though.
i think it may be a weak link in the locking mechanism or it's not catching right.
Too much power...lol
But I used to have this happen to me. Mine was because the plastic sleeve piece on the hatch striker (pictured below) had started to crack. I did a cheepo fix and just wrapped some electrical tape around it (its what I had available and it was black) and it worked better then it ever had since I owned the car.
Good advice... I will check the striker, but from what I recall, there is no plastic sleeve, only metal. There is hope!
Never too much power!!!
you can also get the plastic pieces from the help section at advance or auto zone they come in a pack of 4 and is about $3
yep, the plastic sleeve was gone. I wrapped the striker in electrical tape but it seems like the only time I get to work on my car is in the middle of the night, when slamming a hatch would surely wake someone up. I'll give it a shot today... thanks Dr. Shift... Good to know. I'll probably be heading down to either place soon anyway.
1 - 8 of 8 Posts
