1 - 14 of 14 Posts
I have a 347 with victor JR heads and a Holley EFI intake AFM Hi Rev cam and PMS the car made 352 on the dyno it goes 115.22 at 11.91 with a 1.60 60 FT I think with my set up it should make more power
what do you guys think ?
What kind of fuel system are you running?
Sounds about right. My buddy had a 347 with victor jrs and victor jr intake and 750 mighty demon that made 388 to the wheels and ran 11.6 @117 I think. The good part is it went 9.7 @134 on the spray!
I have a 306 with aluminum heads and a 2800 ilb car and I went 11.68 @117.4
What does it weigh with driver? Is this a stick car?
seems slow to me but my buddie has one thats slower, 12.50's @ 110.00 but it had bad problems that night ! i seen a 347 car with afr 165 heads, performer rpm intake and 750 dp make 344 to the wheels and ran 11.60's @ 116.00 !
What kind of heads, cam, EFI? What kind of power are you making?
Performer RPM, compcam 232/240 @50 565/574 @50 with a carb. Roughly 10.75 to 1 comp. ratio. I have never taken it to the dyno yet. Still smoothing off the rough edges...
It does seem rather slow...comp ratio? cam? more specs? fuel? driver? We need some more facts...
Discussion Starter #12
I ues a 30 lb injector with 75 mm thorttle body with C&L pipe I leave on the 2 step at 3900
Rick Anderson said I need a bigger thorttle body like a 90 and need to work on my suspension get to hook and leave at 5500 to 6500
1 - 14 of 14 Posts
