1 - 20 of 23 Posts
Well I wish I could tell you this was some off the wall different setup but Id be lying.. Its your typically BUDGET LS turbo fox. I would say 90% of the parts are used. As of yesterday I have owned the car for 2 years and its already done some street racing and been in a few videos. Figured it was time to throw it up on TECH.
Quick run down:
04 LM7 5.3 {regapped rings##
228/228 cam
pac springs
ls9 headgaskets
ebay headstuds
s475
th400 manual vb
e85
160lb injectors
magnafuel 4303
Sorry for the pics being in black and white. Only a handful of people knew about the build until till ran.
How I bought the car
5.3
Without these two I couldn't have done it!! Two kick azz guys
my buddy kevin did all the wiring!! amazing job!
before
after
he modded the Tahoe DBW pedal
my buddy dave did the turbo kit. I bought the hotside from him
To get it too this point here was the $$$$$$ break down! I bought as much used stuff as I could and searched for the best deals I could. I tried to spend the money where it was needed.
Mustang build sheet
Car $850.00
Motor complete w/harness&ecu $850.00
Trans w convertor&shifter $1000.00
K-member w/mounts $400
Trans mount $50.00
Rails $140.00
$3290
Cam $399.00
Springs $300.00
Pushrods $100.00
Ls9 gaskets $100.00
Studs $60.00
Cell $100.00
$4349.00
Reg $175
Fuel lines and fittings $230
Coil overs rear w/strange $200.00
Lower arms $50.00
Turbo $575.00
Pan $150.00
Turbo kit w/ intercooler $275.00
Rad $85.00
$6089.00
Injectors/pump/filters/injector driver $750.00
Axles/brakes $550.00
$7389.00
Boost controller $600.00
Wastegate $350.00
$8339.00
Yoke-joint $75.00
Gauges and wideband $580.00
$8994.00
A-arms/camber casters $100
Front brakes/wheels $300
Frame connectors - Xmas
Battle boxes $60
Strange struts $100
Coil overs $75
Co2 bottle/Reg $100
Anti roll bar $200
Driveshaft loop $70
Bump steer kit $100
$10,099.00
Intercooler piping kit $67
Electric fan $110
Vacuum box $12
$10,288.00
$300 new edge brakes
$250 gears and bearings
$10,838.00
Discussion Starter #12
Around here everyone roll races to I haven't been to the track with it. I have raced it on 14psi and 18psi. The car runs hard! Out with some friends. BL750 GTR and 5.3/484 LS FOX!!
Discussion Starter #14
My little boosted family.. My DD 2014 F150 TREMOR {3.5 twin turbo## of coarse the coupe and my wifes 2013 Escape {1.6 ecoboost##..
very nice build. And break of parts and cost!!!!
Discussion Starter #17
badass build! doing a very similar setup with a LQ4.
Thank you!! 6.0's are nasty!!
I'm on the fence on what to do next....
I'm either going to gen 3.5 my current motor {swap pistons and rods from a gen 4 5.3## or go LY6 {gen 4 6.0##. Both routes are cheap. Gen 4 5.3 parts are $150.00 and the 6.0 shortblock is $650.00. Might also swap to 243/799's and a tbss intake with 87mm tb.
Then sell this LM7 and use the money to upgrade the 475 to a billet 480 with race cover. its like $699 for the upgrade.
Thank you!! Took about a year to build.
Discussion Starter #18
Here is the run with the BL750 GTR. Put down 721whp. He jumped the start and Punched out 1 car. On 14psi I passed him and put 1 one him before we let out for a corner. BL says that package traps 138-140 and runs high 9's
http://youtu.be/2JKHQCllq8w
Discussion Starter #20
The teal fox in the picture above. His at the time we raced was a LH6 5.3 {aluminum block gen 4##,lil John cam,Holley hi-ram, billet s484. On 10psi he trapped 150.
He is on 12psi
Me 14psi 2nd 18psi 3rd
http://youtu.be/3pJvlrcMi_4
You cant tell the ending. He got me by 3 nose to nose. On 30psi he went [email protected] He went gen 4 6.0 with tsp heads and cam. Went [email protected]
1 - 20 of 23 Posts
