1 - 16 of 16 Posts
I installed the MSD Street Fire ignition kit (distributor, coil, box) and hooked it all up, seems fine except the tach now doesn't work (factory tach). The instructions state to hook the gray wire from the box to the coil wire.
WHich wire under the hood is the coil wire? I was told the green wire in the factory coil harness but there are two wires. Does it matter which one?
Discussion Starter #2
I touched the ignition box tach wire to both green wires...one at a time of course. No start, no run. Where does that gray MSD tach wire go?
supply a diagram
Which diagram are you speaking of?
When I got the kit, I also got the adapter harness, so other than hooking up the hot and ground wire to the battery, it was plug and play, except, midway on the harness, one gray wire for the tach.
wiring diagram
you dont do elec without one
i looked it up
stock is coil neg
with your ign use the gray
however you must have a tach compatible with its output
you may need a specific adapter
talk to msd
c/p
INOPERATIVE TACHOMETERS
If your tachometer fails to operate with the CDI installed you may need a Tach Adapter from MSD Ignition. Before
getting an Adapter, try connecting your tachometer trigger wire to the Gray Wire. This output produces a 12 volt, square
wave (see page 1). If the tach still does not operate, you will need a Tach Adapter. There are two Tach Adapters:
PN 8920: If you are using the Magnetic Pickup connector (Green
and Violet wires) to trigger the CDI, you will need the
PN 8920.
PN 8910: If your tachometer was triggered from the coil negative
terminal (voltage trigger) and you are using the White
wire to trigger the cdi you will need the PN 8910.
I just looked up their number and will call them in the morning.. I'll post the results. Thanks a lot.
you have two coil neg wires
one for ign control the other for tach
on a side note
your stock ignition is superior to this one, why are you installing this one?
Discussion Starter #12
I am not sure which wire is the tachometer trigger wire. I was told one of the green wires from the coil plug. Either way, the tach didn't work and the car wouldn't run.
I'm no electrical guy at all. Always hated it. I am not sure which way my tach gets it's signal. While i do have a Fox Thunderbird, I would guess that is similar to the Mustangs. I'm looking for more T-Bird specific info.
Discussion Starter #13
8910......I'll check it out.
As far as hooking up the kit, I was using the diagram included with the kit and the adapter harness. No guessing. I was careful about every wire. Where to hook up the gray eluded me. I appreciate your help, and your time. I'll look at the 8910 now.
Discussion Starter #14
I was installing it because I had it. It was a brand new kit I got for literally a trade. Never opened box. If it has no real purpose on my car, I may pull it and move along. I have no issues with that at all.
I wouldn't install it on my car,
i would not give it to a friend, but i might sell it to a stranger far away.......
if you installed it like they said, they also assume you know how your tach is triggered and the signal it needs as they tell you the output signal of their box
you probably need the adapter, ie signal converter......again which i dont like..
Discussion Starter #16
I just came in the house. I removed it from the car and put it on the workbench. Story over. Done. Finished. Now all I need is an NOS Motorcraft TFI module for the MSD distributor.
Indy, I appreciate your help. Thanks.
1 - 16 of 16 Posts
