Is there a kit for the feed and return line that I can buy for my MPT70? Preferably one that I can tap into the oil pan instead of taking the pan off to weld on a fitting. Thanks.
Moderator
I do not know of any kits but you can probably get all the fittings from a hardware store. The feed line itself you probably could not get in a hardware store but could use an old nitrous line. The turn line can be a 5/8 hose. As far as the pan if using a hose then you use a nipple fitting just like how a Vorturd is done and no need to weld anything.
