1 - 8 of 8 Posts
I'm planning on mounting a 62mm turbo in the bumper with a built-in wastegate.
The car is a 96 cobra and the downpipe will dump directly down.
Anything wrong with mounting Turbos in the bumpers?
The only real issue is oil flow. You'll need a pump to send it back to the oil pan
doesnt matter if its technically sitting higher than the oil pan. the issue is with the oil return line. if it doesnt have enough downward slope like described above youll have issues. the hellion twin kit is designed by professionals and even it requires a scavenge pump, which actually comes with the kit. so basically your going to need one
So the optimal setup would be right between the engine and the fan like most single turbo kits?
1 - 8 of 8 Posts
