I have a new Windsor block going into my car this week and since it is out of the car, I was wondering if there are motor mounts that are better than stock to put in with the new engine.
I am assuming that the motor mounts currently in the ar are similar from mod application to mod application. Considering this engine is going into a Crown Vic and not a Mustang are there motor mounts that will work for me?
Thanx.
windsor being?
a 99 model year gt block? not a 302 or anything right? As far as after market mounts for the mod motors, I've only seen solid steel mounts. However, i'm not sure if they are the same as the CV's. good luck!
It's a mod motor all right! Where can I find the solid steel mounts? I might be able to see if they can work for me.
