I was doing a bit of car guy day dreaming, I hypothesized would a Coyote 5.0 supercharger such as a TVS unit or Whipple fit on a Voodoo 5.2? Ya know just for the hell of it. I would venture to guess yes but then again I am probably wrong.
Anyone know if these parts are interchangeable? I though I saw somewhere that people have put Voodoo intakes on Coyotes could this be done vice versa and with a supercharger?
The voodoo engine is coyote based. Yes it wil physically bolt right on. They can interchange almost anything. A voodoo block can be used with stock coyote crank and rods. Voodoo has a larger 3.700 pistons so you end up with a 5.2 coyote. You can also swap heads if you get the right cams.
