Status
Not open for further replies.
1 - 20 of 49 Posts
Selling some misc. DOHC & SOHC parts. Prices and details are below. Let me know if you have any questions. Shipping is extra. Thanks.
Engine:
-1996-1998 Cobra Exhaust Manifolds-Pair………………………………..$65.00
-1996-1997 Cobra DPFE(Sensor For EGR Valve)....………………….$45.00
-1996-1998 Cobra DPFE/EGR Tube Shield/Bracket...……………….$25.00
-1996-1998 Cobra Idle Air Control Valve………………………………….$50.00
-1996-1998 GT & Cobra EGR Valve........………………………………..$50.00
-1996-1998 Cobra EGR Tube……………………………………………….....$25.00
-1996-1997 Cobra Smog Pump Air Valve………………………………….$50.00
-96-97 Cobra Smog Pump Air Valve Pair w/ Connecting Hose...$95.00
-1997 Cobra A/C Compressor w/ Pulley & Clutch Assembly………$75.00
-1997 Cobra Power Steering Pump w/ Pulley…………………………….$75.00
-1997 Cobra Factory Pistons & Connecting Rods-Set of 8……….$80.00
-1997 Cobra Radiator………………………………………………………….......$40.00
-96-00 2V & 96-99 4V Water Pump…………………………………………..$35.00
-1996-1997 2V/4V Positive/Negative Battery Wiring Harness....$50.00
-Cobra Oil Pan………………………………………………………………............$35.00
-Cobra Windage Tray………………………………………………………….......$25.00
-Cobra Oil Pump……………………………………………………………….........$25.00
-Cobra Oil Pump Pick-Up Tube………………………………………………....$25.00
-2003-2004 Cobra Factory Supercharger Pulley……………………….$35.00
-2V Thermostat Housing-Each..........………………………………………$10.00
-1996-1998 Knock Sensors-Pair……………...……………………………….$30.00
-1997 DOHC Wiring Harness(PCM To Bulkhead)…………………………$95.00
-Steeda 4.6 Underdrive Alternator Pulley………………………………….$15.00
-96-98 DOHC Inlet Tube(Back of MAF To Throttle Body)………..$40.00
-2004 Cobra Throttle Body & Inlet……………………………………………$75.00
-03-04 Cobra Cold Air Kit(Black Steel Tube-Fenderwell Type)…$50.00
-03-04 Cobra Belt Guard……………………………………………………….....$30.00
-96-98 Cobra Coolant Crossover Tube w/ Sensors & Plug……....$75.00
-24 lb./hr. Injectors-Set of 8…………………………...................……$50.00
-24 lb./hr. Injectors-Set of 8(Pencil Type).......................……$50.00
-19 lb./hr. Injectors-Set of 8(1400 Miles)........................……$50.00
-2004 2V 5-Speed Radiator(1400 Miles)……………………………………$75.00
-1999+ DOHC Power Steering Reservoir Bracket....................$20.00
-1997 DOHC Fan Assembly…………………………………………………......$95.00
-Mark VIII DOHC Thermostat Housing……………………………………….$25.00
-1997 DOHC Starter……………………...…………………………………….....$75.00
-Lash Adjusters(Set of 16)……………………………………………………...$40.00
-Cam Followers(Set of 16)……………………………………………………....$60.00
-2V/4V Rear Main Seal Mounting Plate w/ Bolts……………………….$20.00
-1997 Cobra ABS Module…………………………………………………….....$150.00
-1999 Fuel Pump/Sender Assembly w/ 255 LPH Pump………………$75.00
-1999-2004 2V Mustang Fuel Rail w/o Schrader Valve…………...$25.00
-1999-2004 2V Mustang Coil-On-Plugs(Set of 8)…….……………..$80.00
-2V Saleen Crank/Early Water Pump Underdrive Pulleys……......$40.00
-K&N Air Filter(# E-0945)(1996-2004 2V/4V Mustang).………....$25.00
-K&N Injection Performance Kit w/ Heat Shield(96-01 2V/4V)..$50.00
-K&N Injection Performance Kit w/o Heat Shield(96-01 2V/4V).$40.00
-MAC Cold Air Kit(# 3499)(1996-2001 2V/4V Mustang)…….…….$40.00
-96-04 2V/4V Mustang Oil Pan(Tapped/Powdercoated/New).…$60.00
-Diablo Sport Computer Chip(Red)…………………………………………….$25.00
-Superchips Computer Chip(Silver)……………………………………………$25.00
-96-98 2V Alternator Bracket(w/o Aluminum Crossover)…….....$15.00
-99-04 2V Alternator Bracket(w/o Aluminum Crossover).....…..$15.00
-Vortech T-Rex Fuel Pump……………………………………………………....$50.00
-Front O2 Sensor w/ Green Connector....………………………………..$25.00
-Rear O2 Sensor w/ Blue Connector………………………………………….$25.00
-Rear O2 Sensor w/ Purple Connector……………………………………….$25.00
Brakes:
-2004 Cobra Rear Rotors-Pair(Freshly Turned)…………………….….$60.00
-1997 Cobra Front Rotors-Pair(Freshly Turned)……………………….$80.00
-1997 Cobra Front Rotor(Freshly Turned)…………………………….….$40.00
-1997 Cobra Rear Rotors-Pair(Freshly Turned)…………………….….$60.00
-2004 Mustang GT Rear Brake Lines-Pair(1400 miles)………………$25.00
Suspension/Drivetrain:
-1997 Cobra Spindle/Hub Assembly-Passenger Side………………$75.00
-1997 Cobra Struts-Pair………………………………………………………….$35.00
-1997 Cobra Shocks-Pair………………………………………………………..$25.00
-1997 Cobra Quad Shocks-Pair………………………………………………$20.00
-1997 Cobra Upper Control Arms-Pair…………………………………….$20.00
-1997 Cobra Front Springs-Pair………………………………………………$30.00
-1997 Cobra 2-Point K-Member Brace……………………………………$20.00
-2003 Cobra IRS Lower Control Arm-Drivers Side…………………$100.00
-2003 Cobra IRS Lower Control Arm-Passenger Side……………$100.00
-2003 Cobra IRS Sway Bar w/ End Links………………………………..$40.00
-2003 Cobra IRS Inner/Outer Tie Rod Assembly……………………..$40.00
-2003 Cobra IRS Sub-Frame Assembly……………………….………….$150.00
-2004 Mustang GT Factory Clutch Cable(1400 miles)………………$30.00
-1994-2004 Ford Front Lower Control Arms w/
Polyurethane Bushings-Pair(26,000 miles)……………………………$125.00
-10.5” 8-Bolt Cast Iron Flywheel.........…………………………………….$50.00
-11.0” 8-Bolt Cast Iron Flywheel……………………………………………….$50.00
-8.8” 28-Spline Trac-Lok Differential…………………………………………$75.00
-Ford Racing 8.8” 3.73 Ring & Pinion…………………………………………$75.00
Interior/Exterior:
-1994-2004 Factory Shift Handle...................…………………….$15.00
-2003-2004 Mach 1 Shaker Bracket(Cast Aluminum)……………..$40.00
-1997 Cobra Deck Lid Assembly w/ Wing(Black)……………………$125.00
-1994-1998 Mustang Headlight Assembly-Drivers Side……………$40.00
-1994-1998 Mustang Headlight Assembly-Passenger Side………$40.00
-1994-1998 Mustang Side Marker Light-Drivers Side………………$25.00
-99-04 Mustang Factory Headlight Assembly(Clear)Drivers...…$40.00
-99-04 Mustang Factory Headlight Assembly(Clear)Passenger.$40.00
-1994-1998 Mustang Fuel Door Assembly-Black………………………$25.00
-1999-2004 Mustang Fuel Door Assembly-Silver………………………$25.00
-99-04 Mustang GT/03-04 Mach 1 Fog Light Assembly-
Drivers Side(New)…........................................................$40.00
Passenger Side(New)......................................................$40.00
-1996-1998 Mustang Tail Light w/ Black Bezel-Drivers Side……$75.00
-1996-1998 Mustang Tail Light w/ Black Bezel-Passenger Side.$75.00
-1997 Cobra Rear Rotors-Pair(Freshly Turned)........$60.00
Could you do 50 shipped on these to Jacksonville FL? I have it in paypal and thats about all, I am all tapped out.
Thanks,
Chris
1 - 20 of 49 Posts
Status
