What do you need to do to the factory cross member to make it work with a tko??
i believe all you have to do is grind the tack welds off so you can move it forward or back then retack.
i'm sure someone that has done this will chime in to confirm.
it needs to be shifted all the way back.. you can either remove the tack welds and slide it back or just use a crossmember out of a aod car which is already moved all the way back.
