1 - 11 of 11 Posts
Fox double hump for a stock 5.0 that will be entered into a 14 hour endurance road race.
It's a chump/lemons car so we are limited in the amount of money we can put into the car our I would install a road race pan.
Looking for pics or what ever you have to get ideas on where to weld baffles, scrapers, etc.... To keep from losing oil pressure in the turns.
Super Moderator
I had some baffling welded into mine (see below), but unfortunately oil pressure still took a sharp drop on sharp corner entries coming off hard braking zones. It's better now with a canton road race pan. All that said, there are lots of folks who swear you don't need any of it unless you're pulling massive sustained G's with R-comps.
Were you having oil pressure issues before you modded the pan and did it seem to help you even though it wasn't 100% for you?
Super Moderator
I only had the stock gauge to go by before I made the pan mod, and installed a mechanical gauge when I did the pan, so I don't have a direct precise before/after. But the conclusion I've drawn is that it didn't do much, if anything at all.
Figure out a way to hide a 3 QT Moroso Accumulator or a Canton Accusump in the car. When I was auto crossing a 5.0 mustang I tried fixing low oil pressure issues with a deep sump Steeda pan. It helped a little but a Moroso Accumulator solved it completely.
onteresting thread.
I am planning on modifying a stock sump for my build. I want to box it up to make it larger and install trap doors so the oil will be where i want it...
Great thread.
We ae putting a 5.0/T5 in our '91 RX7 Lemons car as well. On our 3rd rotary engine, its time for something new.
Any other ideas for the oil pan? We've got a plasma and welder, any build pictures out there to give us some ideas?
Thanks!
I spoke to a guy who is nearly dominating chumps racing with a 5.0 he's in Texas.
He recommended stock pan with an extra half quart of oil. Stock radiator with heavy duty clutch fan and bearings machined loose.
1 - 11 of 11 Posts
