1 - 20 of 21 Posts
Read Only
I have an old modified factory K-member as per the mustang performance handbook by William Mathis. It was built by a now defunct company from Texas I was told. Would it be worthwhile to install this in my 91 coupe? I am not going to race this car and I don't want to spend the money to go coil over. It will be mostly street driven with possibly an open track day once or twice a year. I have H&R race springs with Bilstein struts and also 04 cobra front control arms and steering rack. I am doing a 5 lug swap so most of the front end will be taken apart already. What are your thoughts and opinions?
I wonder which company that was, I used to live in Texas.
Re: worthwhile, all depends on if you want to give it a shot. Dropping the k-member is supposedly not that hard, it's the plumb bobbing and lining it back up that's the pain.
Eh, hard to explain, it's been 20 years and I was in college. I'd say they didn't really have a shop, they were some guys trying to make a name for themselves to break into the saleen/steeda type of market. Lots of hype, mostly. They had one car that I can recall, their Slot Car. Used to bring it up to Texas A&M Sports Car Club events. We had TONS of foxbodies in the 90s due to there being lots of used Texas Dept. Public Safety highway patrol cars auctioned off. As a result, we had the fastest group of foxbody drivers in the country (many of whom have gone on to win jackets or set track lap records). Anyhow, I don't recall the Slot Car being any faster than a decent ESP car, certainly not a 3rd gen or Madarash. They had my buddy Todd Farris, CP champ, drive it and I think he told them, "Eh, it's a mustang. Needs more spring, bar, tire, and shocks."
They were some of the first to run 16x8s, lol at knowing now these are tiny wheels. They also claimed their input helped Ford design the SN95 suspension...um, not much changed there as far as I can tell.
Mathis is legit but there is some debate regarding antidive, etc. If you really want to study up, go search corner carvers for threads mentioning Mathis.
Read Only
Thank you very much for that information. I will study up on it more. Let me ask you one thing, if it was your car, would you bother doing it or just leave the stock one in and add all the other parts I have?
I am debating doing Mathis's changes now to my sorta CP car since a new tubular MM k-member would incur a ridiculous weight penalty. If it is just a non- competition car with minimal HPDE, I'd probably skip it.
If I'd been running the stock k for a while so that a change could be detected, I might give it a try. Without a baseline, seems to be a lot of work for maybes or uniqueness.
Do the swap.
Nearly 20 years ago I did the mods to a K member per the Mathis book. I installed it in a '93 Cobra that I road raced. It was well worth the work.
Since you only have to swap K members you swap will be easy.
Before you go to far you should check the center-to-center distance of the LCA bolt holes on both the modified K and your stock K. If these holes are moved inboard you will lose camber and wheel track width if you use your stock LCAs.
You may need to go with longer LCAs like the 87-88 TBird arms or the SN95 LCAs.
When I did this swap I first went with the TBird LCAs but later built my own tubular LCAs and converted to coil over springs.
Read Only
Discussion Starter #13
Thank you Jim. I appreciate advice from someone who has first hand experience. I have lower control arms from an 04 cobra. They have the higher durometer rated bushings. I have a new set of Del-a-lum bushings as well. Would you use them or stick with the rubber ones?
On a car that will be mostly street driven I would stay with the stock bushings.
If you went with aftermarket bushing the only thing you would notice driving it on the street is the increase ride harshness & noise they transmit to the body.
Read Only
Discussion Starter #15
Ok. I will leave the rubber ones in and keep the Del-a-lum ones on the shelf just in case I get involved in tracking the car.
A lot of work to swap crossmembers? I spent so much time doing the Mathis mods to mine, removal and installation was nothing. I didn't change antidive from stock, like Mathis recommends, due to what the internet said. Can you see the original holes? I think Mathis moved one up 3/4", and the other 1/8". It was definitely an improvement and a requirement. All the other Mustangs we go against have done it.
How long did it take to do the actual mods? I was under the impression it was measure twice, drill once. Guess I need to re-review that section of his book.
Took me about 20 hours of labor, alone no help, first time doing this, spread out over a couple weekends.
Measuring once, twice, three times and more. Drilling. Cutting, fitting. . . fitting again. . . and again, then finally welding. Lastly, painting.
I'm sure it could be done much faster but I was really taking my time making sure it came out square.
I raised the control arm mount points 2 inches and did not change the factory anti-dive.
Griggs makes a modified stock K-member if you have $1200 to shell out. :rofl:
I ran into interference problems with the factory FCAs (SN95 w/ ginormous rear bushings) when I did a k-member for my car. I could have windowed the k-member at the offending locations but decided to wallet fangle a set of MM FCAs instead.
There was a poster here with the screen name "Toys" that had a thread with some info on doing Mathis mods to a Fox k-member. It might be one place to look...
1 - 20 of 21 Posts
