1 - 20 of 26 Posts
authorized corral.net advertisers
This is the finest intake kit you can buy for your 05'-08' GT, the MMR kit replaces the restrictive factory airbox, mass air sensor housing, panel filter and rubber inlet tube with our high flow mass air sensor housing, washable element filter, and 4 inch Inlet tube! adds up to 35 RWHP* and a smooth, deep growl for the new 3 valve V-8 engine (no noise increase at idle or cruise speeds.) These are real kits that retain all smog equipment, not plastic plumbing tubing that have no provisions for the factory breather and smog equipment or Cast aluminum that heat sink and decrease horsepower. The MMR intake kit even made 5 More HP than the K&N kit in the recent dyno shootout in 5.0 magazine!!
Now available in red, black or silver!
Kit Includes:
* 4" High Flow Intake Tube
* High Flow Mass Air Flow Sensor
* 4 Ply Innovative Turbo Silicone couplers
* Stainless steel Hose Clamps
* S&B 1 Million Mile High Flow, Twin Cone washable air filter with Chrome cap
* Smog/Valve cover breather tube with factory style plug and play connector
* Complete instructions & Lifetime Warranty
* The MMR kit will not void your factory warranty (fed. law (15 U.S.C. 2302(C))
$269.99 kit as shown
www.modularmustangracing.com
805 650 1853
*The MMR kit provides great gains with no other changes but for optimum performance an MMR tune is recommended.
This is somewhat correct, the Standard MMR Annihilator kit will produce gains of up to 15HP without a tune, the MMR Annihilator kit w/High flow tube does require a tune for peak horsepower (up to 36 HP) but will only make about 18HP without a tune and the A/F ratio is leaner than we generally would like to see so for the complete kit with high flow tube we recommend the the MMR/SCT tuner.
Thank You !! Visited your website -
TTT
It depends on many factors, including compression ratio and bolt ons but we usually work to maintain a High 12 low 13 to 1 ratio for optimum power and reliability, of course this is only on a N/A application.
MMR
1 - 20 of 26 Posts
