1 - 20 of 81 Posts
authorized corral.net advertisers
AS SEEN IN MUSCLE MUSTANGS AND FAST FORDS MAGAZINE HELLION TURBO INSTALL!
MMR's new Fuel system is now available and in stock:
The most complete and well tested fuel system available for your Supercharged or Turbo Charged 05-07 GT's making 400-800 HP. This kit will support up to 800 RWHP and includes the following:
Brand new GT500 Twin Fuel Pump system,wiring harness and fuel control module (not a pair of aftermarket pumps hose clamped to a GT sending unit like the other inferior brands-this can cause a lean condition and damage your engine and fry your fuel pump control module!!)
NO core charge like the other brands-MMR uses ALL new parts!!
Stainless Steel 100 Micron Cleanable fuel filter - NEVER REPLACE A FUEL FILTER AGAIN!
Steel braided or NHRA style pushlock tubing available (shown below with NHRA pushlock tubing)
Shelby GT 500 Fuel pump control module and plug in wire harness-no cutting or splicing like the cheap kits!
Billet AN fittings with O-rings for a guaranteed NO LEAK system
MMR Billet Fuel Rails
True Y block design for correct fuel distribution (instead of feeding one fuel rail and then the other like inferior systems, this causes the injectors furthest from the fuel pump to run lean and cause catostrophic failure!!!)
1/2 (-8) feed line
Complete Install instructions for easy installation
$1299.99
805 650 1853
1 - 20 of 81 Posts
