1 - 9 of 9 Posts
Here are some miscellaneous parts I have laying around for sale.
Mostly stock useless stuff to me but to someone else who knows... If you see something you need just make an offer. Thanks
Mike
Things for sale:
-stock 302/5.0 crankshaft
-stock 302/5.0 mustang oil pan
-stock 02 mustang gt rear disc brake calipers and brackets (18k miles)
-stock 02 mustang gt 4.6 sohc 6 bolt flywheel (2) (1-15k miles, 2-40k
miles)
-stock 02 mustang gt 4.6 sohc clutch set (15k miles)
-stock 02 mustang gt 4.6 sohc egr tube
-stock 02 mustang gt 4.6 sohc rear abs sensors
-stock 02 mustang gt 4.6 sohc parking brake cables
-stock 03-04 mustang cobra rear tie rods (inner and outer, both sides)
-stock 02 mustang gt rear sway bar
-stock 02 mustang gt 4.6 sohc oil pump and pickup tube (15k miles)
-stock 02 mustang gt 4.6 sohc exhaust manifolds
-stock 02 mustang gt 4.6 sohc clutch cable (2) (1-15k miles, 2-40k
miles)
-stock 02 mustang gt 4.6 sohc power steering pulley
-stock 02 mustang gt 4.6 sohc A/C compressor pulley and clutch
-stock 02 mustang gt 4.6 sohc alternator pulley
-stock 02 mustang gt 4.6 sohc serpentine belt tensioner (15k miles)
-stock 02 mustang gt 4.6 sohc throttle body and elbow with 2 1/8" NPT
ports for boost gauge, n2o, etc
-stock 02 mustang gt front struts (12k miles)
-stock 02 mustang gt rear shocks (12k miles)
-stock 02 mustang gt rear spring isolators (12k miles)
-stock 02 mustang gt 4.6 sohc 6 bolt crankshaft (15k miles)
-stock 02 mustang gt 4.6 sohc upper and lower control arms
-stock 02 mustang gt 4.6 sohc front swaybar end links (12k miles)
-stock 02 mustang gt 4.6 sohc rear quad shock brackets
-stock 02 mustang gt 4.6 sohc rear disc brake dust shields
-99-04 cobra rear disc brake dust shields
-stock 02 mustang gt 4.6 sohc 5-speed driveshaft (31 spline tailshaft
yoke)
-stock 02 mustang gt 4.6 sohc power steering cooler (15k miles)
-stock 02 mustang gt 4.6 sohc steering shaft (15k miles)
-stock 02 mustang gt 4.6 sohc power steering reservoir
-2 bassanni exhaust pipes, 2-1/2" ball and socket connection with 3"
diameter tubing, one is 12" long and the other is 15" long, stainless
steel, brand new never used
-stock 02 mustang gt 4.6 sohc water pump pulley
-stock 02 mustang gt 4.6 sohc harmonic balancer (15k miles)
-stock 02 mustang gt 4.6 sohc DPFE sensor, purge solenoid and bracket
(15k miles)
-stock 02 mustang gt 4.6 sohc battery tray
-stock 02 mustang gt 4.6 sohc lower radiator hose (15k miles)
-stock 02 mustang gt 4.6 sohc transmission/o2 harness (1R33-15525)
-stock 02 mustang gt 4.6 sohc oil dipstick and tube
-stock 02 mustang gt 4.6 sohc vacum tube assembley
-stock 02 mustang gt 4.6 sohc power steering reservoir bracket
-stock 02 mustang gt 4.6 sohc air intake tube assembley with k&n
filter (3k miles -like new)
-stock 02 mustang gt 4.6 sohc mass air meter (12k miles)
-stock 02 mustang gt 4.6 sohc 5 speed ECM (18k miles, MDE2)
-brand new Ford ECM for 02 mustang gt, new never used, may fit other
years, was told I needed ECM by local shop and when it didn't fix the
problem I was stuck with it (FBD0)
-Canton oil filter adaptor for Ford engine with standard filter (fits
FL1A threads- SBF/BBF/etc does not fit modular threads to my
knowledge). Needs fittings welded on because threads are messed up.
Currently has one 90* 10AN fitting and one straight 10AN fitting.
-brand new Russel stainless braided brake hoses for front cobra calipers
-brand new k&n filter #RE-0870. Round tapered filter, 4" inlet, 9" long
-stock 02 mustang gt 4.6 sohc oil filter/radiator hose adaptor without
cooler
-Steeda aluminum 3/16" spring spacers (front pair)
1 - 9 of 9 Posts
