Super Moderator
PA has a great reputation with their mini-starters. You might want to check them out. IF you are on a budget and trying not to spend a lot you can use the '99-present V-6 starter. I have one of these V-6 starters on my '88 GT.
Thread 109444
Thread 241028
Here's another good thread.
Thread 171780
Mini-Starter
The mini-starter is a direct bolt in with a little different wiring setup. The wiring setup is also very simple with a detailed illustration, basically a two wire setup.
