1 - 8 of 8 Posts
engine setup:
boss block 333ci
twin to4e turbos
aod
blah blah blah
anyways, this will be my first time with methanol and a transbrake. ive run both before but never at the same time. i have a snow stage one and the point at which it activates is adjustable based on boost pressure. my question is, should the methanol spray while on the brake?
snow recommends having the meth turn on at about half your max boost pressure. i want to run 18-20psi (if the turbos will support it, ive had them up to 15psi on the last motor). that means the meth should turn on at 9-10psi. i dont know how much boost ill make on the brake. last motor made 5psi at 3200rpm. it was a joke tho. scratches in the walls and pistons slapping around, amazing it ran at all. last motor was 8.5:1, this motor is 9.5:1 so i expect ill be able to push the converter to 3500rpm easy and with the extra rpm and the higher compression/better built motor i would expect 7-8psi on the brake (maybe? IDK). if i run 18psi or even 20, should i set the meth to come on at say 7psi while on the brake (in hopes to make even more power/boost off the line) or have it turn on just after the launch?
all comments welcomed and appreciated
I would want it off the line for sure, thats like having nitrous but not spraying it off the line........
I thought Meth was based off WOT? I guess you can get more technical with it and make it boost based?
It's an electric pump so you can activate it just about any way. Boost, a push button, wot switch, window switch, etc. Boost switch is what comes in the kit
Dont know if i can help i run a single turbo and 14 psi..I run a stage 2 snow performance..mine starts coming in at 4 psi all in by 7/8 psi....I hit 4 psi pretty fast....
I tried the meth on the brake and the car hated it and bogged. I may not have something right in the set up of it though.
I say it would depend on how much boost you make on the trans brake. Look at it this way if you were racing the car and you hit xx PSI would you being used meth? If yes, treat the boost the same on the brake. If it doesn't like it then wire the meth to be PSI based but be off when the brake is on. I have see guys do the same with N20, to help flash the converter.
Sent from my PI86100 using Board Express
1 - 8 of 8 Posts
