Combo is:
stock 302 shortblock
61 cc afr 165 heads (about 60cc after head surfacing)
vortech sci 6.87 3.12
Not a big cam, 16hg-ish at idle
2-3lbs @ 3500ish where meth comes on
6-6.5 lbs @ 5k
about 9 @ redline
Combo really done @ 5500 (old msd box pulling timing and me pulling timing as well)
snow 625ml nozzle pre compressor
So what should I do? Move Act sensor to discharge so I can better tune for saftey of methanol OR add a post compressor nozzle and use the factory location as planned?
My air fuel is already pretty rich @ low 11's with 0 degree washer fluid. I though maybe if I add another nozzle, I could just turn the screw on the meth controller to where it isn't spraying as much. Maybe being post compressor would help cool the iat a bit.
6-6.5 lbs @ 5k
about 9 @ redline
