Give it a try and find out if you need to go bigger. Even with it recirculating, you will hear it flutter if it's not able to dump enough air. The biggest drawback I've had from the standard Bosch bpv is that it's not adjustable. Having it close and build boost around 5 inch/hg of vacuum would be nice, instead of waiting until 0.
Sent from my Z962BL using Tapatalk
