Does anyone have pictures oh how they routed their vacuum lines from the wastegate with a master power turbo and a tial WG?
If the turbo doesn't have a port for a fitting you have to make one. I took my compressor housing off and took it to a machine shop and had them drill it out on a press so it was a better hole than I could've made. Then I took it home tapped it and put my fitting in it. Then I routed a line from the fitting to the port on the SIDE of the wg. Works flawlessly.
