I've got a turbo smart boost tee and a tial 38mm wg, now I'm confused as there are a bunch of different ways it's showing to install these on every site I read, anyone have a proper layout of where the lines are supposed to run?
Please call me Mike
I think you should install the controller in the vacuum line for the wastegate. It works by limiting vacuum/boost signal to the wastegate. Some of them have a check valve. The flow should go towards the wastegate so when it reaches the wastegate at a certain psi it will open the spring.
